changes.mady.by.user Gergana Lilkova
Saved on Jul 08, 2022
Saved on Jul 20, 2022
Base material – Allows you to select the base material to which the bump effect is added.
Bump map – Specifies the bump/normal map that is going to be used.
Bump amount – Specifies a multiplier for the bump effect.
Image RemovedImage Added
