This page covers the parameters for of VRayVRmatMtl.
width
60%
The VRayVRmat material uses materials loaded with .vrmat and .vrscene files.
While the .vrscene is a full V-Ray scene export format holding both materials and geometry, the .vrmat format holds only materials. Such files can be exported from 3dsMax, Maya, Rhino or SketchUp.
File – Loads a .vrmat or.vrscenefile containing one or more V-Ray materials.
Material name – A list of all V-Ray materials saved inside the loaded .vrmat or .vrscene file.
width
5%
width
35%
Fancy Bullets
type
circle
Since V-Ray 6, update 1, the VRmat converter tool used for converting materials in 3ds Max into .vrmat files has been deprecated. Earlier versions still use the tool.
