UI Text Box | |||||||||||||||||||||||||
The example above shows how to produce negative luminosity delta using two VRayCompTex maps. The second VRayCompTex map is plugged as a Source B to the first VRayCompTex map. The Operator is set to Subtract (A-B). |
