Example: ID Generator Tex
In the following example, a VRayMultiSubTex controls the transparency of an object
. The difference from the standard transparency is that here, we can't see the back faces of the object.
The VRayMultiSubTex's Get ID from is set to ID generator tex. The plugged ID
generator tex. is a VRaySamplerInfoTex with a Type - Transparency level. Note that the Loop through textures mode must be off.
The VRayMultiSubTex is used in the Opacity slot of the material and the actual transparency is controlled by the value of the color in the first ID
slot. Manually this slot has to be set to a value of 0. You could have more ID slots with values of 1, 2, and 3, etc which represent different depth levels.
The Default Color has to be set to black.
UI Button | ||||||||
Section | |||||||||||||||
Section | |||||||||||||||||||||||||||||||||||||
