width15%
width70%
Image slider
afterLabel100
beforeLabel50
Panel
borderStylenone
Multiplier Value = 0
Panel
borderStylenone
Multiplier Value = 50
Panel
borderStylenone
Multiplier Value = 100
width15%
The Radius option of VRayEdgesTex is not yet available when the render engine is set to V-Ray GPU.
Fancy Bullets
typecircle
  • When applied to displaced or subdivided objects, VRayEdgesTex normally shows the edges of the original mesh, as shown on this displaced teapot:
  • VRayEdgesTex cannot simulate toon-style outlines on objects. Instead, use VRayToon render effect to add outlines.
  • Currently, when used as a bump map in glossy materials with the Blinn or Ward shaders, VRayEdgesTex can create dark edges. To avoid this, use the GGX shader instead:
