Rotation X/Y/Z – – Rotates the light shape in relation to the target.
Override shape – When enabled, the light profile within the .ies file is ignored. The Shape parameter defines light shape for calculating shadow softness. Sharp shadows are generated with the point type.
Shape – Specifies a shape (and its orientation) for the VRayIES light when Override shape is enabled. Some shapes (shown below) enable additional options for size. See the Shape example below.
width
30%
point
rectangle
circle
sphere
vertical cylinder
horizontal cylinder (length)
width
5%
width
30%
vertical horizontal cylinder (width)horizontal
cylinder ellipse (length)
horizontal cylinder ellipse (width)
ellipse ellipsoid (length)
ellipsoid (width)
elliptic cylinder
width
5%
width
30%
ellipse (width)
ellipsoid hor. elliptic cylinder (length)
ellipsoid hor. elliptic cylinder (width)
vertical circle
vertical ellipse
cuboid
Height – Specifies the height for applicable light Shape types.
Width – Specifies the width for applicable light Shape types.
Length – Specifies the length for applicable light Shape types.
Diameter – Specifies the diameter for applicable light Shape types.
