This page provides information on the Light Meter utility.
The VRayLightMeter helper is an aid for evaluating how a scene is illuminated. It is intended to simulate the use of a real-life light meter used in photography and film production.
The information presented by the VRayLightMeter does not change or otherwise affect the lighting in the scene; it only reports on it. This helper is intended to provide information so you can make adjustments to the scene's lighting at your own discretion.
UI Path:
||V-Ray menu|| > Create > Helpers > V-Ray Light Meter
||Create menu|| > Helpers > V-Ray > V-Ray Light Meter > Click and drag in viewport
||Command panel|| > Create tab > Helpers > VRay category > VRayLightMeter button > Click and drag in viewport||V-Ray menu|| > Create > Helpers > V-Ray Light Meter
VRayLightMeter
Section | |||||||||||||||
MaxScript Methods
