Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkVRayProxy
Proxy Objects
Allows an external mesh to be imported at render time only. Since the proxy object's geometry isn't present in the scene, it doesn't take up resources and allows the rendering of meshes with triangle counts higher than 3ds Max itself can handle.
Textboxcard
CardPageLinkVRayInstancer
Particle Instancer
Creates instances of other objects over particles from a ParticleFlow system.
Textboxcard
CardPageLinkVRayDecal
V-Ray Decal
Projects one material on top of another regardless of the target UV set.
Textboxcard
CardPageLinkVRayGaussiansGeom
V-Ray Gaussian Splats
Creates a 3D scene from images or videos.
Tools and Utilities
Div
classdashboard
Textboxcard
CardPageLinkOBJ GEO PLY to .vrmesh converter
Convert OBJ GEO PLY to V-Ray Proxy
A command-line tool that converts a variety of mesh files into .vrmesh format for V-Ray Proxy Objects.
Textboxcard
CardPageLinkV-Ray mesh viewer
V-Ray Mesh Viewer
Allows the user to preview static and animated V-Ray mesh (.vrmesh) and alembic files.
Textboxcard
PageToIncludeInstallation
CardPageLinkV-Ray Scene Exporter
Exports the geometry, lights, and shaders in a scene into a .vrscene file.
Textboxcard
PageToIncludeGetting Started
CardPageLinkV-Ray Scene Converter
This tool converts all scene materials and raytraced shadows to versions optimized for V-Ray.
