HideElements
cssselector#tocVertical, #tocHorizontal
This page provides information on the Frame Info rollout.
width60%
The Frame Info rollout allows you to quickly check the size, dimensions, and contents of the loaded cache file for the current frame. The information is for display only, and cannot be changed on this rollout. To change the input file, use the Preview & Render Cache Path field on the Input rollout.
UI Expand
titleUI Path: ||Select V-Ray Volume Grid|| > Command panel > Modify tab > Frame Info rollout
width5%
width35%
Container Dimensions - If a file is successfully loaded, shows the size of the bounding box of the cached contents for the current frame, in scene units. Prints [No Frame Loaded] otherwise. This parameter ignores any transformations (such as Scaling) applied to the transform node.
