UI Text Box | ||
In V-Ray 6 for 3ds Max, this tool has been moved to the V-Ray Menu and is no longer available in the quad menu. For earlier V-Ray versions, go to 3ds Max Quad Menu > transform section > V-Ray scene converter. |
UI Text Box | ||
The V-Ray Scene converter doesn’t convert Autodesk materials. To convert Autodesk materials, use the 3ds Max native converter. |
Scene Converter
