width60%
Enabled – Enables or disables loading of the .vrscene.
File (*.vrscene) – Allows you to browse for and specify the .vrscene file. Please note that you can also load a V-Ray Scene by dragging and dropping a .vrscene file directly in your viewport. To specify that a file is a part of a sequence, the string <frame0n> should be added in order to replace the current frame number, where n is the frame padding. For example scene_01.vrscene needs <frame02> to load the sequence; scene_001.vrscene -<frame03>; scene_0001 - <frame04>.
Load mode – Specifies how to load the .vrscene file.
All – Loads the .vrscene file with all its geometry, lights, shading, volumes, etc.
Geometry – Loads the .vrscene file with geometry and shading only.
UI Text Box
typetip
Geometry Load Mode has several advantages:
  • the instanced scene uses much less memory;
  • much faster render times;
  • makes possible of billions of instances of a geometry.
Flip Axis – Controls which axis is used as a vertical - the Y or Z axes for the loaded vrscene. You can choose between:
NoneNo changes in the axes are applied.
Auto – It aligns the vertical axis of the vrscene with the vertical axis in the scene in cases where the vrscene was not exported from 3ds Max. Use the Auto mode when loading a USD file.
Flip – Switches the Y and Z axes.
Scale – Allows the vrscene or USD to be quickly scaled up or down.
Add Lights – When enabled, uses any lights in the .vrscene file.
Animation
Use Anim. Overrides – Enables Animation overrides.
Playback – Specifies how to read the animation in the .vrscene
Loop  Plays the entire animation, then restarts on the initial frame.
Play once  Plays the animation once, then displays the last frame of the animation for all further frames.
Ping-pong  When the end of the animation is reached, the animation is reversed.
Still – Displays only one frame.
Start  Sets the frame for the first frame of the animation.
Length  Sets the length of the animation. If this value is less than the total number of frames, the animation is clipped. If it is greater than the number of frames, the Type option determines how the extra frames are interpreted.
Offset  Shifts the start frame.
Speed – Speed multiplier for the animation. A value of 1 plays the animation at normal speed.
Scene Overrides
Use Scene Override – Enables the scene override.
From File (*.vrscene) – Allows you to specify a .vrscene that will be used for the scene override.
Edit Override Snippet – Launches an editor window that allows code snippets for editing the scene override settings.
UI Text Box
typewarning
The Snippet can only override the values of parameters of nodes which exist in the .vrscene file. If a parameter or node is not available there, you can't edit or add it.
A material from 3ds Max's Material Editor can be selected by name from this window and used as an override material if desired.. This material must have been directly assigned to the VRayScene node, or assigned to the VRayScene node with a Multi/Sub-Object material.
Snippet Examples:
Code Block
titleExample: Material Override
collapsetrue
//Material Override Example
//Override object's assigned material
Node <Sphere001*>{
    material=Asphalt;
Code Block
titleExample: Disable Light
collapsetrue
//Light Override Example
//Disable a light
LightRectangle <VRayLight001*>{
    enabled=0;
Code Block
titleExample: Object Visibility
collapsetrue
//Object Visibility Example
//Make an object invisible
Node <Teapot001*>{
    visible=0;
width5%
width35%
