HideElements
cssselector#tocVertical, #tocHorizontal
This page provides information on the Render Elements tab under V-Ray GPU.
width60%
The Render Elements tab is available in the Render Setup window when V-Ray GPU is selected as the RendererRender Elements are a way to break out renders into their component parts such as diffuse color, reflections, shadows, mattes, etc. to give the ability to fine-tune aspects of the image in compositing or image editing applications.
V-Ray GPU provides support for Render Elements within some limitations. For information on the render elements available in V-Ray GPU, visit the V-Ray Supported Features page.
On the right is the Render Elements tab when V-Ray GPU is selected as Renderer.
UI Path: ||Render Setup window|| > Render Elements tab (Renderer set to V-Ray GPU)
width5%
width35%
