With the Progressive Image Sampler, the default Render Max render time (min) is set to 1. 0, which might be insufficient for some scenes. You can reset this to 0 .0 min and rendering will continue min. This means that rendering continues until the Noise threshold is reached.
3. You can further refine the noise levels from the Progressive Image sampler rollout by adjusting the Noise Threshold and placing a 0 value for the Render time (min).
4. You can control the amount of AA vs shading samples (for materials/lights/GI) using the Min shading rate parameter in the Image Sampler rollout but the default value is optimized to work well for the majority of scenes.
