  1. Do not close the error report window during this whole process.
width14%
width35%
Image Added
3ds Max 2022 and earlier
width2%
width35%
Image Added
3ds Max 2023
width14%
2. Click on the View Report Details option for 3d Max 2022 and earlier, or the Report Details option for 3ds Max 2023.
Image Removed
width14%
width35%
Image Added
width2%
width35%
Image Added
3ds Max 2023
width14%
3. In 3ds Max 2022 or earlier, hover 3. Hover your mouse over 3dsmax_minidump.dmp to see its location.
Image RemovedIn 3ds Max 2023, click View report contents option.
width14%
width35%
Image Added
width2%
width35%
Image Added
3ds Max 2023
width14%
4.  Go to that location and find the .dump file. It is better to send the dumpdata.zip file, if available, as it contains all the necessary dump files.
width14%
width35%
Image Modified
width2%
width35%
Image Added
3ds Max 2023
width14%
Collecting the 3dsmax_minidump.cmp file if Autodesk Error Report Windows is not Available
Sometimes 3ds Max freezes without showing the Autodesk Error Report Window or V-Ray exception  exception occurs:
1. Open the Windows Task Manager from the Start Menu.
 2. Right-click on the application in the Processes tab to select the Create dump file option, while the app displays the notification that unexpected error has occurred.
If you are rendering with V-Ray GPU in 3ds Max or V-Ray Standalone and a crash occurs, a VRay.dmp file should be is generated automatically. The VRay.dmp file is located by default in the Windows Temp folder:
