V-Ray supports multi-layered G-Buffer output required for writing .rla and .rpf files, as well as by many 3ds Max render effects. V-Ray will automatically generate generates the G-buffer channels requested by the image output and the render effects so there is no need to select these manually.
3ds Max Channel Name
Supported by V-Ray
Description
Z
Status
colourGreen
titleYes
Depth buffer (distance to the camera XY plane).
Material Effects
Status
colourGreen
titleYes
The material ID.
Object
Status
colourGreen
titleYes
The object node ID that is set through the Properties dialog of an object.
UV Coordinates
Status
colourGreen
titleYes
The surface UV coordinates. V-Ray will always output outputs the UV coordinates for mapping channel 1.
Normal
Status
colourGreen
titleYes
The surface normal relative to the camera.
Non-Clamped Color
Status
colourGreen
titleYes
The real unclamped pixel color, before any color mapping is applied to the pixels. Like with the scanline renderer, this channel does not store atmospheric effects.
Coverage
Status
colourGreen
titleYes
The contribution of an object to the image pixel.
Node Render ID
Status
colourGreen
titleYes
A unique ID assigned to each node by the renderer.
Color
Status
colourGreen
titleYes
The material color for the object. Like with the scaneline scanline renderer, this does not include any atmospheric effects.
Transparency
Status
colourGreen
titleYes
The material transparency for the object. Like with the scanline renderer, this does not include atmospherics.
Velocity
Status
colourGreen
titleYes
The surface velocity relative to the camera.
Sub-Pixel Weight
Status
colourGreen
titleYes
The contribution of an object to the image pixel including transparencies.
Sub-Pixel Mask
Status
colourRed
titleNO
A bit mask for the contribution of an object to a pixel. The Sub-Pixel Mask channel is meaningless when AA filters, depth of field, and motion blur are taken into consideration, which is why V-Ray does not support it.
Fancy Bullets
typecircle
  • V-Ray takes antialiasing filters into account when generating the G-buffer channels, in contrast with the default scanline renderer of 3ds Max. This may cause differences in the way some render effects work. If this is a problem, turn off the AA filter from the Image sampler rollout. Also, avoid using AA filters with negative components (Catmull-RomMitchell-Netravali) when generating a G-buffer; 3ds Max cannot handle layers with negative coverage and V-Ray will ignore ignores those when creating the 3ds Max G-buffer.
  • Generating a correct multi-layer G-buffer requires extra memory. This is because the 3ds Max G-buffer only supports scanline-style writing. However, V-Ray renders in buckets and cannot provide the data in scanline order. To work around this, V-Ray stores all the G-buffer data while rendering and then writes it at once into the final image.
  • G-Buffer layers are now generated correctly in distributed rendering mode. This means that render effects like image motion blur will now work in DR mode too.
