width60%
Cryptomatte is a method developed by Psyop for efficiently encoding accurate mattes. It typically uses three to five automatically generated render channels stored in a multichannel OpenEXR file which removes the hassle of creating dozens or hundreds of Multimattes. Using the Cryptomatte plugin for NUKE or Fusion, mattes can be extracted through directly picking objects or entering object names.
Compared to the Multimatte Render Element, Cryptomatte offers the following:
Fancy Bullets
typecircle
  • Does not require a setup with object IDs, etc.
  • Only requires a fixed number of additional render elements, typically four.
  • Cannot be propagated through reflections or refractions.
UI Text Box
typenote
With V-Ray 5, update 2, the Cryptomatte Render Element works with Progressive Image Sampler as well.
UI Text Box
typenote
The Cryptomatte Render Element supports reading of Multi/Sub-Object materials.
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRayCryptomatte
Image RemovedImage Added
width5%
width35%
