This page provides information on V-Ray IPR within 3ds Max.
V-Ray Interactive Production Rendering (IPR) provides interactive rendering using the V-Ray and V-Ray GPU renderers.
Settings for the behavior of the VFB when using IPR rendering can be found in the IPR options rollout (Render Setup window > V-Raytab) for the V-Ray renderer and in the Render Settings rollout (Render setup window > V-Ray tab) for the V-Ray GPU renderer.
Using V-Ray IPR
The IPR option is accessible from the V-Ray Frame Buffer (VFB).
To use V-Ray IPR:
In the Render Setup window, make sure the render engine is set to V-Ray. To open the VFB, click the Last VFB button on the Toolbar, or go to the respective Render Setup rollout for V-Ray or V-Ray GPU engine.
Section | |||||||||||||||||||||||||
- To start IPR, click the Start interactive rendering button on the VFB toolbar. You can make changes to the scene while the rendering continues, and the changes are rendered automatically.
Make sure you've selected the right camera to render from. If you have more than one cameras in the scene, hold left mouse button on the Start interactive rendering button to display the list of cameras.
2. When the scene is rendering, the Start interactive rendering button changes to the Refresh interactive rendering button. Click this button to restart the rendering at any time. The progress bar at the bottom of V-Ray Frame Buffer tracks the rendering progress of the current scene.
3. Use the Stop rendering button to stop V-Ray IPR. After stopping, you can click Start interactive rendering again to restart IPR
Additional Features
While IPR is running, if the Fit resolution to VFB option is enabled in the IPR options rollout, the render refreshes to fill the VFB when the VFB window is resized. The render output size also changes accordingly. The same setting for V-Ray GPU can be found in the V-Ray tab > Frame buffer rollout > Fit IPR resolution to VFB.
In addition, the IPR rendering refreshes whenever the Region Render area is redrawn.
UI Text Box | ||
The Test Resolution button is inactive in IPR when Fit resolution to VFB is enabled. |
Viewport IPR
Viewport Parameters
Fancy Bullets | ||
