width55%
The 3ds Max Render Setup window hosts many V-Ray settings for both V-Ray and V-Ray GPU. Choosing the V-Ray GPU engine changes the available settings. For more information about the V-Ray GPU render settings, follow the link.
This section provides information on render setup with the V-Ray engine.
UI Text Box
typeinfo
The Common tab contains no custom or unique V-Ray settings. For more details on the parameters found under this tab, please refer to the 3ds Max help documentation.
UI Text Box
typeinfo
With V-Ray 6, Hotfix 1, the render settings are now kept when switching between V-Ray and V-Ray GPU.
UI Expand
expandedtrue
titleUI Path: ||Rendering menu|| > Render Setup...
||Main Toolbar|| > Render Setup button and then set Renderer to V-Ray
||Rendering menu|| > Render Setup... and then set Renderer to V-Ray
||Render Setup window|| > Renderer > V-Ray
Image RemovedImage Added
width5%
width40%
Selecting the V-Ray Renderer
