The settings under the GI tab control the global illumination for the scene.
UI Path:||Render Setup window|| > GI tab (Renderer set to V-Ray)
width
5%
width
35%
Image RemovedImage Added
Rollouts
The rollouts under this tab include:
width
20%
UI Text Box
size
medium
Global Illumination rollout
Controls GI settings and sets the primary and secondary GI engines. Determines which additional rollout(s) rollouts are exposed. Find out more: Global Illumination rollout
width
5%
width
20%
UI Text Box
size
medium
Primary engine rollout
Rollout for the Primary engine (Irradiance map, Brute force, or Light Cache). Find out more about each primary engine: Irradiance map, Brute force, and Light Cache
width
5%
width
20%
UI Text Box
size
medium
Secondary engine rollout
Rollout for the Secondary engine (Brute force, or Light Cache). Find out more about each secondary engine: Brute force andLight Cache
width
5%
width
20%
UI Text Box
size
medium
Caustics rollout
Enables and controls the rendering of caustic effects. Find out more: Caustics rollout
