width60%
This section allows you to control and fine-tune various aspects of the irradiance map. This rollout is enabled only when the irradiance map is chosen as the Primary engine on the Global Illumination rollout
For more details on how the Irradiance Map engine calculates GI, please see the Irradiance Map page under Indirect Illumination.
You can also make use of the Irradiance Map Viewer, a standalone tool that allows you to navigate through the 3D version of a scene presenting the GI samples taken.
UI Text Box
typewarning
Irradiance Map GI engine is deprecated. It doesn't support some of the new V-Ray features and will be soon removed as an option.
UI Path: ||Render Setup window|| > GI tab > Irradiance map rollout
(When Irradiance map is set as the primary GI engine)
width5%
width35%
Image RemovedImage Added
Default Parameters
