A Search bar where you can specify a filter criteria with wildcards. | |
Filter case sensitivity. | |
Filters by metadata. | |
Sorts by name. | |
Opens the Material Editor when applying a material to selection. | |
Forces Enables the real-world scale option of VRayBitmaps (when adding the material to a scene or selection). | |
Forces Triplanar Enables triplanar mapping on VRayBitmaps (when adding the material to scene or selection). | |
Opens the V-Ray Material Library Companion Tool where you can add the content to asset library. | |
Specifies thumbnails size. |
Fancy Bullets | ||
