Official Release
Build: 5.00.03
Date: 16 Date - 16 June, 2020
Release notes for other V-Ray versions
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray 5 for 3ds Max
urlhttps://download.chaosgroup.com/?platform=49&product=47
New features
V-Ray
  • Add light path expressions support through mode of VRayLightSelect;
  • Add RGB primaries override for VRayBitmap option in the Color management;
  • Implement blue-noise optimization for the DMC sampler;
  • Support for rendering in ACEScg color space with option to recognize the texture color space from the file name;
  • Improve precision when rendering large scenes;
  • MikkTSpace support for tangent normal maps;
  • New version notifications in the new VFB and render settings About section;
  • Include the V-Ray AppSDK Python binding with the installation;
V-Ray GPU
  • Add support for the VRayNormalMap rotation parameter;
  • Support for Environment and Self Illumination contribution for VRayLightSelect;
  • Add support for Out-of-Core codepath;
  • Support for 2D displacement;
  • Rendering of Phoenix FD Particle Shader in Fog mode;
  • Add support for OSL shaders;
  • Add support for Cellular map;
  • Add support for BerconTiles and Bercon Wood maps;
  • Implement a per-device GPU memory tracker;
  • Resumable rendering with progressive sampling;
VRayDirt
  • Add Streaks generation options;
New VFB
  • Add magenta-green tint slider to the White Balance color correction;
  • History saved render settings loading and comparing;
  • Background color correction;
  • Filmic tonemap color correction;
  • Image search in the History based on the saved scene name and note text;
  • Solo button Alt+mouse click enables only one light and toggles all the rest in LightMix;
  • Special element "Rest" in LightMix that includes everything not in the other elements;
  • Support for rendering without a memory frame buffer;
  • Undo for Layers actions;
  • Add entirely new implementation of VFB with integrated Layers compositing;
VRayNormalMap
  • Add Map rotation parameter;
VRayPhysicalCamera
  • Add EV parameter;
VRayProxy
  • Support common particle interface (IParticleObjExt) for Alembic that can be used with VRayInstancer and Phoenix FD;
VRaySun
  • Implement "Improved" Sky model;
VRayVolumeGrid
  • Velocity streamline preview;
.vrscene exporter
  • Add option to export only selected nodes;
V-Ray scene converter
  • Implement a converter for Physical Material to VRayMtl;
LightMix
  • Add support for lights post-processing in the new VFB;
V-Ray Asset Browser
  • A material library browser utility for the V-Ray Material Library;
  • Add material library downloader working both standalone and as part of the installation;
V-Ray Material Preview
  • Render the material previews with a custom .vrscene;
VRayMtl
  • Add Coat and Sheen layers;
  • Add simple presets;
VRayHairNextMtl
VRayCarPaintMtl2
  • Add new car paint material with more precise flakes filtering and reduced memory usage;
VRayUVWRandomizer
  • Add a texmap that should be used solely with the VRayBitmap's and VRayTriplanarTex's mapping source input with stochastic tiling support;
VRayMultiSubTex
  • Add randomized hue, saturation and gamma variance options;
  • Add new Random by Face material ID/Object ID/Element modes;
VRayBitmap
  • Rename VRayHDRI to VRayBitmap;
VRayCompTex
  • Add new blending modes Color Shift, Color Tint, Blend Alpha Straight, Blend Alpha Premultiplied;
VRayTriplanarTex
  • Ability to be used as Mapping source for VRayBitmap;
VRayPointCloudColor
  • Add a map that supports PointCloud Color Channel;
VRayLightSelect
  • Support for environment lighting;
Installer
  • New installer experience with integrated bundled products: Chaos License Server, Chaos Cloud client and V-Ray Material Library;
Modified features
V-Ray
  • Add UI option to enable the MikkTSpace calculations from Global Switches;
  • Add UI option to switch back to the Native 3ds Max material swatches;
  • Optimize conversions between sRGB and ACEScg color spaces when using an OCIO configuration;
  • Faster calculation of VRaySun;
  • Remove some old stale options from the Global switches;
  • Remove the Use local subdivs from Global DMC along with the subdivs parameter of Brute force GI, materials and lights that was dependent on it;
  • Simplify the Color mapping options;
  • Simplify the Light cache options;
V-Ray Cloud
  • Animated parameters of VRayDistanceTex are not exported properly;
  • Animated position of geometry with large stationary interval differs;
V-Ray Cloud/V-Ray GPU
  • Add initial support for tyFlow instances rendering;
V-Ray GPU
  • Automatically disable Out-of-core rendering when the engine type is RTX;
  • Implement Box sampler type for VRayVolumeGrid;
  • Add support for VRayUVWRandomizer stochastic tiling options;
  • Optimize memory footprint for motion blurred geometry both on CPU and GPU;
  • Skip degenerate faces when serializing the Embree tree;
  • Support for matte objects through VRayObjectProperties;
  • Support for VRayCarPaintMtl2 and VRayFlakesMtl2;
V-Ray GPU IPR
  • Endless updates when having a camera with tweaked tilt and shift parameters;
V-Ray Standalone
  • No image buffer rendering is implemented with new VFB, still processed output is written;
VRayDenoiser
  • Remove "Generate render elements" UI option;
VRayBitmap
  • Automatically set the transfer function and RGB color space for normal maps;
VRayLightSelect
  • Add Subsurface mode;
VRayMtl
  • Add some tooltips;
  • Add fabric presets based on Sheen;
  • Add a "Default" preset;
  • Use GGX shadowing for all NDF-based BRDFs;
VRayOSL
  • Print warnings for unsupported OSL shader parameters;
New VFB
  • Add "None" option to hide the secondary color info in the status bar;
  • Add a progress bar for the loading of the History images;
  • Add image fitting types option and "Save in image" to the Background layer;
  • Group the History compare buttons in a single flyout button;
  • Implement renderer stats;
  • Preserve the original RGB channel when saving;
  • Save persistent settings independent on the scenes;
  • Support for color corrections and settings transfer for V-Ray Cloud;
  • Bucket outline improvements;
  • Enable the denoiser for history and loaded images;
  • Various usability improvements;
New VFB/VFB
  • Render button to execute Render command instead of Render Last;
VFB
  • Use all supported formats as default filter for loading image;
V-Ray Asset Browser
  • Add "Use real world scale" and "Use triplanar mapping" options on import;
  • Rename the "ME" button to "Open ME on apply" to be more descriptive;
  • Put the converted material nodes in Slate Material Editor for displayed materials after scene conversion;
V-Ray Toolbar
  • V-Ray Toolbar to look relative to the vrenderXXXX.dlr directory for icon files to aid network installations;
VRayALSurfaceMtl
  • Prevent values for the SSS radius parameters that cause artifacts;
VRayVolumeGrid
  • Speed up and use less memory for blending frames having Grid Velocity with Time Bend controls;
Bug fixes
V-Ray
  • Body objects are always rendered with draft quality;
V-Ray IPR
  • Incorrect VRayMtl with displacement texture after IPR update;
V-Ray Cloud
  • Per-frame export for animated parameters of Noise map;
V-Ray GPU
  • Crash or artifacts when VRaySwitchMtl uses the default submaterial (since Beta 1);
  • Renders may get overexposed with VRaySun when changing scene units due to overflow;
V-Ray GPU CUDA
  • CPU bucket rendering crashes with On-demand mip-mapped textures;
  • Crash with Fractal_3.osl OSL shader;
  • IPR crashes when rendering Out-of-core with CPU device;
V-Ray GPU RTX
  • OSL maps crash with shaders with string outputs;
  • Random crash with particle system in the scene;
VRayDisplacementMod
  • Vector displacement produces wrong geometry with scaled objects;
VRayIES
  • Incorrect light cutoff when using the light shape for both shadows and illumination;
VRayOSL
  • Crash after deleting maps linked to VRayOSLOutputSelector;
  • Shader and VRayOSLOutputSelector output values are reset when path to the OSL asset is modified;
VRayPhysicalCamera
  • Transfer exposure to camera is not working properly with Exposure Value (EV) mode;
VRayProxy
  • Wrong VRayParticleTex shading with alembic particle color (since Beta 1);
VRayVolumeGrid
  • .AUR files where the grid data is over 8GB are unreadable, fix requires Phoenix 4.20 and newer;
  • Meshes are rendering without motion blur and the Mesh preview is broken when a modifier is applied;
  • The resolved cache paths show huge numbers if looking at a frame outside the Timeline Origin - Play Length range;
New VFB
  • Crash when loading Layer presets (since Beta 2);
  • Crash when saving all channels to .vrimg with LightMix, LUT and high resolutions;
  • MaxScript error that prevents rendering occurs when submitting scenes to Thinkbox Deadline;
  • Random crash with bucket rendering after multiple frames;
  • Render view not updated when compare is disabled with no image loaded;
  • Slowdown when rendering a scene with LightMix on V-Ray GPU;
  • Sometimes Lens Effects layer UI becomes disabled no matter the enable flag;
.vrscene exporter
  • Error when exporting a scene with empty mesh object;
  • Long string parameters containing escape characters get trimmed after 1023 symbols;
  • 3ds Max 2021 hangs when creating Double Sided material in Slate Material Editor;
V-Ray Toolbar
  • Missing icons with light theme (since Beta 2);
