The V-Ray installer will automatically remove any previous installations. This will allow you to seamlessly upgrade from previous versions. If you experience problems you can manually uninstall the previous versions to perform a clean install. For more information please refer to the Uninstall V-Ray page.
Operating system
Maya Version
Installer Name
Windows 64-bit
Maya 2019
vray_adv_60000_maya2019_x64
Windows 64-bit
Maya 2020
vray_adv_60000_maya2020_x64
Windows 64-bit
Maya 2022
vray_adv_60000_maya2022_x64
Windows 64-bit
Maya 2023
vray_adv_60000_maya2023_x64
Before running the installation, make sure your Windows account has administrative privileges.
Run the installer.
1. Upon the start of the installation, Windows may ask you for permission to run the installer with administrator privileges. Please confirm.
width
20%
width
60%
width
20%
2. You will be presented with the V-Ray licensing agreement. Please take a moment to review the agreement. Enable the I acceptthe Agreement checkbox and click Install to proceed with standard installation.
If you need to customize your V-Ray installation, click the Advanced button.
Expand
title
Click here to see the Advanced installation options...
width
20%
width
60%
width
20%
V-Ray type
The available installation types are:
Full – This is a full installation and includes all components as described in the “Installation overview” section. It will allow you to use V-Ray in Maya for Distributed or Network Rendering, to run IPR render server, use V-Ray SDK, and have V-Ray license server on this machine. Standalone only – This installation includes V-Ray Standalone and IPR render server. Please choose this option if you plan to use this machine only for Distributed Rendering with V-Ray Standalone and an IPR render server. Add firewall exceptions – Automatically adds firewall exceptions so IPR for Maya and V-Ray Standalone can run uninterrupted.
width
20%
width
60%
width
20%
Directories
Here you can specify the installation paths. Please check if the default folders are correct.
Help make V-Ray even better – Participate in the improvement decisions for future version of V-Ray. No intelligence property is violated when agreeing to participate in the feedback program. Chaos does not gather scenes, assets, materials, etc. What Chaos receives is user preferences on just a few key render settings and the resulting render times. The point of this feature is to improve V-Ray's performance and the user experience. This preference can be changed at any time later on from the V-Ray Render Settings > Settings > About V-Ray > Feedback program settings. For more information, see the Chaos Telemetry page.
width
20%
width
60%
width
20%
Licensing
In this step, you can specify whether the V-Ray license server runs locally or on another machine.
If you select the Remote option you have to fill in the IP address of your V-Ray license server in the field Primary License Server. Please leave the port 30304 unchanged. An AlternateLicenseServer is used when the primary one does not respond.
3. If you select the Local Licensing Option, you are presented with the Chaos License Server installation.
width
20%
width
60%
width
20%
Chaos License Server Options
4. At this step you can choose the license server directory.
Migrate data during installation – When enabled, transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option will install License Server with all settings at their defaults and any custom settings from the previous installation will be lost.
Add firewall exception – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you will need to manually add firewall exceptions later.
width
45%
width
10%
width
45%
5. After you click the Install button, the installer will proceed to stop any interfering applications such as the Unified login.
Then, it will uninstall any previous V-Ray versions and install V-Ray on your machine. If the installer detects any applications that need to be closed, they will be listed before being able to continue. Please close them and click Continue.
width
20%
width
60%
width
20%
6. Now V-Ray is ready to render!
Tabs Page
title
macOS
macOS
Operating system
Maya Version
Installer Name
macOS 64-bit
Maya 2019
vray_adv_60000_maya2019_mavericks_x64
macOS 64-bit
Maya 2020
vray_adv_60000_maya2020_mavericks_x64
macOS 64-bit
Maya 2022
vray_adv_60000_maya2022_mavericks_x64
macOS 64-bit
Maya 2023
vray_adv_60000_maya2023_mavericks_x64
Before running the installation, make sure your macOS account has administrative privileges.
Run the installer.
1. Upon the start of the installation, macOS may ask you for permission to run the installer with administrator privileges. Please confirm.
width
20%
width
60%
width
20%
Expand
title
width
20%
width
60%
width
20%
V-Ray type
Full – This is a full installation and includes all components as described in the “Installation overview” section. It will allow you to use V-Ray in Maya do Distributed or Network Rendering, run IPR render server, use V-Ray SDK, and have V-Ray license server on this machine. Standalone only – An installation which includes V-Ray Standalone and IPR render server. Please choose this option if you plan to use this machine only for Distributed Rendering with V-Ray Standalone and an IPR render server. Add firewall exceptions – Automatically adds firewall exceptions so IPR for Maya and V-Ray Standalone can run uninterrupted.
Help make V-Ray even better – Participate in the improvement decisions for future version of V-Ray. No intelligence property is violated when agreeing to participate in the feedback program. We do not gather scenes, assets, materials, etc. What we receive is user preferences on just a few key render settings and the resulting render times. The point of this feature is to improve V-Ray's performance and the user experience. This preference can be changed at any time later on from the V-Ray Render Settings > Settings > About V-Ray > Feedback program settings. For more information, see the Chaos Telemetry page.
width
20%
width
60%
width
20%
Licensing
In this step, you can specify whether the V-Ray license server will run locally or on another machine.
If you select the option Remote you will have to fill in the IP address of your V-Ray license server in the field Primary License Server. Please leave the port 30304 unchanged. An AlternateLicenseServer is used when the primary one does not respond.
3. If you choose the Local Licensing Option, you are presented with the License Server installation.
width
20%
width
60%
width
20%
5. After you click the Continue button, the installer will proceed to uninstall any previous versions and install V-Ray on your machine.
width
20%
width
60%
width
20%
Tabs Page
title
Linux
Linux
1. Save the contents of the installation archive file to a temporary folder (called vray_install_dir below);
2. Open a console and navigate to that folder;
4. Make sure you have given permission to the Installer to run as an executable. That is done with the command chmod +x.Run the installer in the directory for the respective Maya version:
Operating system
Maya version
Installer name
Linux 64-bit
Maya 2019
vray_adv_60000_maya2019_centos7
Linux 64-bit
Maya 2020
vray_adv_60000_maya2020_centos7
Linux 64-bit
Maya 2022
vray_adv_60000_maya2022_centos7
Linux 64-bit
Maya 2023
vray_adv_60000_maya2023_centos7
5. Follow the instructions of the installer; if you had a previous version of V-Ray for Maya, the installer will try to automatically remove it first.
6. Upon the start of the installation, Linux may ask you for permission to run the installer with administrator privileges. Please confirm.
width
20%
width
60%
width
20%
7. You will be presented with the V-Ray licensing agreement. Please take a moment to review the agreement. Enable the I acceptthe Agreement checkbox and click Install to proceed with standard installation.
Expand
title
width
20%
width
60%
width
20%
V-Ray type
Full – This is a full installation and includes all components as described in the “Installation overview” section. It will allow you to use V-Ray in Maya do Distributed or Network Rendering, run IPR render server, use V-Ray SDK, and have V-Ray license server on this machine. Standalone only – An installation which includes VNS and IPR render server. Please choose this option if you plan to use this machine only for Distributed Rendering with V-Ray Standalone and an IPR render server.
width
20%
width
60%
width
20%
Directories
width
20%
width
60%
width
20%
Licensing
8. If you choose the Local Licensing Option, you are presented with the License Server installation.
width
20%
width
60%
width
20%
9. After you click the Continue button, the installer will proceed to uninstall any previous versions and install V-Ray on your machine.
width
20%
width
60%
width
20%
10. Now V-Ray is ready to render!
Some GUI Distributions of Linux may be incompatible with the GUI of the installer. In that case run the installation with -gui=0attribute.
Once you have installed V-Ray for Maya, you can load the plugin from the Maya plugin Manager:
Start Maya.
Open the Plugin Manager from the Windows > Settings/Preferences > Plug-in Manager menu.
Scroll down to the vrayformaya.mll plugin entry.
Check the Loaded and Auto-load options to load V-Ray for Maya.
Click Close.
Register V-Ray Render Server as a Service
You can register the V-Ray Standalone application as a Windows service so that it runs automatically on Windows boot from C:\Program Files\Chaos Group\V-Ray\Maya nnnn for x64\maya_vray\bin\vraymayaspawnernnnn. V-Ray Standalone can now be used as a render server for Distributed Rendering, Network Rendering and rendering with IPR.
Note: nnnn is the Maya version.
Running V-Ray Standalone
V-Ray Standalone is installed as part of the V-Ray for Maya installation. It can be started from C:\Program Files\Chaos Group\V-Ray\Maya nnnn for x64\maya_vray\bin\vray. Once started, you will need to start a command-line rendering by first calling the vray command vray command and then adding parameters to it:
vray -sceneFile = "[v-ray scene file]"
where [v-ray scene file] is a .vrscene file. Start it without parameters Use the -help option to see a list of the available command line options.
Running a V-Ray Standalone Render Server
You can use V-Ray Standalone render servers for distributed rendering, where a single frame is simultaneously calculated across many machines. Before you can use distributed rendering, you have to start the V-Ray Standalone application in render server mode on the machines that you wish to use. To do that, open the application from C:\Program Files\Chaos Group\V-Ray\Maya nnnn for x64\maya_vray\bin\vray
Tabs Page
title
macOS
Loading the V-Ray for Maya Plugin
Start Maya
Open the Plugin Manager from the Window > Settings/Preferences > Plug-in Manager menu.
Scroll down to the vrayformaya.bundle plugin entry;
If you do not see the vrayformaya.bundle entry, you will need to browse explicitly for it. The file is located by default in the /Applications/ChaosGroup/V-Ray/Mayannnn/vray/VRay.app/Contents/MacOS/plugins directory. The plugin will attempt to load a shared library, libvray.dylib, which is installed in the /Applications/ChaosGroup/V-Ray/Mayannnn/vray/lib folder and should be readily accessible for Maya to load without modifying the DYLD_LIBRARY_PATH variable.
Note: do not attempt to make V-Ray for Maya load the libvray.dylib library with the same name for the standalone version of V-Ray, which is located in the /Applications/ChaosGroup/V-Ray/Mayannnn /vray/VRay.app/Contents/libs folder. Attempting to load the V-Ray standalone library into Maya will cause Maya to crash immediately.
V-Ray Standalone is installed as part of the V-Ray for Maya installation. It can be executed using the vray bash script which is normally installed in the Applications/ChaosGroup/V-Ray/Mayannnn/vray/VRay.app/Contents/MacOS/directory, for example:
/Applications/ChaosGroup/V-Ray/Maya2023/vray/VRay.app/Contents/MacOS/vray.bin -sceneFile="[vray scene file]"
You can use V-Ray Standalone render servers for distributed rendering, where a single frame is simultaneously calculated across many machines. Before you can use distributed rendering, you have to start the V-Ray Standalone application in render server mode on the machines that you wish to use. To do that, run the following command from a Terminal window:
where nnnn is the particular version of Maya (2020 etc).
Tabs Page
title
Linux
Start Maya;
Open the Plugin Manager from the Windows > Settings and Preferences > Plugin manager menu.
Scroll down to the vrayformaya plugin entry;
If you do not see the vrayformaya entry, you will need to browse explicitly for the V-Ray for Maya plugin, which is called vrayformaya.so and is located by default in the /usr/ChaosGroup/V-Ray/Mayannnn-x64/maya_vray directory. The plugin will attempt to load a shared library, libvray.so, which is installed in the /usr/ChaosGroup/V-Ray/Mayannnn-x64/vray/lib folder and should be readily accessible for Maya to load without modifying the LD_LIBRARY_PATH variable.
NOTE: do not attempt to make V-Ray for Maya load the libvray.solibrary with the same name for the standalone version of V-Ray, which is located in the /usr/ChaosGroup/V-Ray/Standalone_for_Linux_x64/lib/linux_x64 folder. Attempting to load the V-Ray standalone library into Maya will cause Maya to crash immediately.
V-Ray Standalone is installed as part of the V-Ray for Maya installation. It can be executed using the vray bash script which is normally installed in the /usr/ChaosGroup/V-Ray/Mayannnn-x64/vray/bin/vray directory, for example:
$ /usr/ChaosGroup/V-ray/Maya2023-x64/vray/bin/vray -scenefilesceneFile="[v-ray scene file]"
You can use V-Ray Standalone render servers for distributed rendering, where a single frame is simultaneously calculated across many machines. Before you can use distributed rendering, you have to start the V-Ray Standalone application in render server mode on the machines that you wish to use. This is done with the vrayserver command, for example:
