Code Block |
<DefValues> <Value Name="INSTALL_TYPE" UseOld="1" DataType="value">0</Value> <Value Name="MAYAROOT" DataType="value">C:\Program Files\Autodesk\Maya20xx</Value> <Value Name="PLUGINS" DataType="value">$MAYAROOT\>C:\Program Files\Chaos Group\V-Ray\Maya 20xx for x64\maya_vray</Value> <Value Name="OPEN_CHANGELOG" DataType="value">0</Value> <Value Name="REMOTE_LICENSE" UseOld="1" DataType="value">0</Value> <Value Name="REGISTER_RENDERSERVER_SERVICE" UseOld="1" DataType="value">0</Value> </DefValues> |
Below is a description of the variables of the installer:
MAYAROOT | Specifies the root Maya folder. |
PLUGINS | Specifies the plugins folder for Maya |
INSTALL_TYPE
| Specifies the installation type: 0 - Full 1 - Standalone only For a complete description of each installation type refer to the Installation section. |
| Specifies whether or not to register the V-Ray Standalone render server as a service. 0 - Does not register the V-Ray Standalone render server 1 - Registers the V-Ray Standalone render server |
OPEN_CHANGELOG
| Specifies whether or not to open the Change Log once the installation is complete 0 - does not open the Change Log. 1 - opens the Change Log. |
STDROOT | Specifies the destination folder for IPR files. |
REMOTE_LICENSE
| Specifies whether the V-Ray license server runs locally or on another machine. 0 - the license server runs locally on the same machine. 1 - the server is on a different machine in the network. |
To perform a silent uninstall, the executable of the installer should be run from a Windows command prompt or from a Linux or macOS terminal with the following arguments:
-uninstall=<log full filename> -uninstallApp=<product full name> -gui=0
Fancy Bullets | ||
Performing a silent uninstall of V-Ray on Windows requires running the installer.exe file from the command prompt with the arguments specified in the Overview. In order to To do that, you need to know the full path of the folder containing the V-Ray additional files and the exact name of the product you want to uninstall. Then you can execute the following command:
Performing a silent uninstall of V-Ray on macOS requires running the installer installer executable from a terminal with the arguments specified in the Overview.
Code Block | ||||
/Applications/ChaosGroup/V-Ray/Maya2020/vray/Uninstaller.app/Contents/MacOS/installer.bin -uninstallApp="V-Ray for Maya 2020 for x64" -log="/Applications/ChaosGroup/V-Ray/Maya2020/vray/uninstall/install.log" -gui=0 |
Linux
Performing a silent uninstall of V-Ray on Linux requires running the installer executable from a terminal with the arguments specified in the Overview.
Code Block | ||||
/usr/ChaosGroup/V-Ray/Maya2020-x64/vray/uninstall/installer -uninstallApp="V-Ray for Maya 2020 for x64" -log="/usr/ChaosGroup/V-Ray/Maya2020-x64/vray/uninstall/install.log" -gui=0 |
