In the terminal navigate to the location where you have extracted the vray_adv_60000_maya20xx_mavericks_x64.app file
- Copy the .app file to a location with write permissions.
Using the cd command navigate inside the .app file and go to vray_adv_60000_maya20xx_mavericks_x64.app/Contents/MacOs
In the terminal enter:
./run_installer -gui=0You will be prompted for your password – enter it.
Follow the instructions of the installer and setup the installation in the way you want it to be installed on all machines.
A file named config.xml is created in the folder of the .app file. Move it outside the .app bundle, for example, next to the vray_adv_6xxxx_maya20xx_mavericks_x64.app.
You can now install V-Ray on all machines by navigating to vray_adv_60000_maya20xx_mavericks_x64.app/Contents/MacOs and using the command:
./run_installer -configFile="../../../config.xml" -gui=0 -quiet=1 -ignoreErrors=1
