The Uninstaller originally resides in the following location - C:\Program Files\Chaos Group\V-Ray\Maya 20xx for x64\vray\uninstall
To access the V-Ray uninstaller from the Start menu, search for Uninstall V-Ray for Maya20xx for x64.
This starts the V-Ray uninstaller. Follow the on-screen instructions to remove V-Ray from your system and restore any files overwritten by the installation.
To remove the Chaos License Server, either use the Add/Remove Programs applet from the Control Panel or select
Chaos License Server Group > Uninstall Chaos License Server. Excerpt Include V-Ray Configuration V-Ray Configuration nopanel true
macOS
Uninstalling the Plug-In
If you need to manually uninstall V-Ray, make sure that Maya or V-Ray components are not being used. Double-click the uninstaller.app program, which is normally located in /Applications/ChaosGroup/V-Ray/Maya20xx-x64/vray/VRay.app/Contents/MacOS/uninstall
This will start the V-Ray uninstaller. Follow the on-screen instructions to remove V-Ray from your system and restore any files overwritten by the installation.
/Applications/Autodesk/maya20xx/vray/
To uninstall V-Ray for Maya, start with root permissions the uninstaller program, which is normally located in the /usr/ChaosGroup/V-Ray/Maya 20xx -x64/vray/uninstall/ directory, for example:
