This page provides information on toon outline effect in V-Ray for Maya. For Toon Cel Shading, see the VRayToonMtl page.
Section | |||||||||||||||||||||||||||||||||||||
Basic Parameters
Depth Curve
This rollout enables a curve for controlling the Line Width based on distance from the camera.
Angular Curve
Example: Line Width
This example shows the effect of the Line Width parameter. The Inner Line option is also enabled.
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
Example: Inner Lines
This example shows the effect of the Inner Lines parameter.
Line Width for both images is set to 1.2. In the second image, the Line Color Inner is red and Line Width Inner is set to 2.5.
Example: Affected Objects
This examples demonstrates how the toon effect can be applied only on specific objects in the scene. In addition, different objects in the scene can get different toon effects.
Example: Depth Curve
This example shows the Depth Curve effect. Notice that the curve used here makes the toon lines at the front thinner, while those on the tale are much more pronounced.
Fancy Bullets | ||
