Image File Output
Anchor | ||||
The Translator rollout expands when when Export to a .vrscene file is enabled
Animation
Anchor | ||||
Baking a texture with the settings selected here work with the resolution specified in the Common tab and for the selected object only. Note that the resolution should always be with square aspect ratio (1:1). For texture baking with the means of creating nodes, please see the Texture Baking page.
Renderable Cameras
Renderable Camera works only for Batch rendering.
Resolution
Render View
Scene Assembly
MEL/Python Callbacks
This part of the Common settings allows you to attach different MEL scripts that will be executed at certain points during the rendering process.
