Enabled – – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.specular.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mappingManagement rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
UI Text Box
type
note
There is initial support for Raw Total Light render element on V-Ray GPU.
