width62%
vrayRE_Normals is a render element that stores the camera space normal map using the geometry's surface normals. The Normals Render Element is useful for adjusting lighting in the composite. For example, the red, green and blue channels can be adjusted in compositing software.
Bump maps are not represented in this render element; to include bump maps, use the Bump Normals Render Element.
When Normals Render Element is saved as a separate render channel, its output value is kept between [0;1] range; if saved as a multichannel .exr, its output value is in the range from -1 to 1.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Normals
width25%
width50%
Multiexcerpt include
MultiExcerptNameRE
PageWithExcerptRender Elements
width25%
Image Removed
width5%
width33%
width62%
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.normals.vrimg).
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler rollout in the VRay tab of the Render Settings.
UI Text Box
typeinfo
When using the Progressive image sampler, even if disabled, Filtering will affect the render channel.
width5%
width33%
