width62%
The VRayPtex node loads and uses PTex textures with V-Ray. PTex is a mapping system that applies a separate texture to each face of a subdivision or polygon mesh and therefore requires no UV assignment. A PTex file can store an arbitrary number of textures along with mipmaps and adjacency data used for filtering across face boundaries. For more information on the PTex concept, see the Notes section below.
UI Expand
titleUI Path: ||Hypershade|| > Create panel > VRay section > Other Textures > VRay Ptex
width60%
Image Added
width40%
Image Removed
width5%
width33%
