Section | ||||||||||||||||||||||||||||||||||||||||
Finite Dome
When enabled, the Dome Light is calculated differently, so that it has a physical size in the scene. Especially useful when an HDRI is attached to the light, since this option adds depth to the background. The dome can serve both as a background and to project the light texture on the ground. The Finite dome consists of a ground plane, a hemispherical upper part and a transition area between the two. For more information, see the Finite Dome example.
Example: Setting the scale of a dome light
Align | ||
Options
Advanced Options
