div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkVRayProxy File Formats
Proxy Objects
Allows an external mesh to be imported at render time only.
Textboxcard
CardPageLinkVRayFur
Procedural Fur
Creates simple procedural fur at render time only but not present during editing.
Textboxcard
PageToIncludeInstallation
CardPageLinkVRayPlane
Infinite Plane
Creates an infinite plane at render time that will have no visible end.
Textboxcard
PageToIncludeGetting Started
CardPageLinkVRayMetaball
Metaballs and iso-Surfaces
Geometric primitive that can create a raytraced iso-surface out of an existing particle system.
Textboxcard
CardPageLinkVRayClipper
Section Clipper
Geometric primitive that can clip away parts of the scene without modifying the actual geometry.
Textboxcard
CardPageLinkVRayRenderableCurve
Renderable Curve
Turns a curve into a renderable object, without intermediate conversion to paint effects or polygons.
Textboxcard
CardPageLinkVRayDecal
V-Ray Decal
Projects one material on top of another.
Textboxcard
CardPageLinkV-Ray Enmesh
V-Ray Enmesh
Uses geometry as a texture to “coat” objects.
Modified Geometry
div
alignleft
classdashboard
Textboxcard
CardPageLinkVRayDisplacement
Geometry Displacement
Allows higher detail to be added to a geometry object through displacement.
Textboxcard
CardPageLinkVRayNURBSTessellation
NURBS Tessellation
Node that controls the quality of the NURBS subdivision of multiple NURBS surfaces.
