HideElements
cssselector#tocVertical, #tocHorizontal, #tocVertical
This page provides information about the V-Ray NURBS tessellation option in V-Ray for Maya.
width75%
The VRayNURBSTessellation node is used to control the quality of the NURBS subdivision of multiple NURBS surfaces with a single node.
UI Expand
titleUI Path: ||Select NURBS surface|| > V-Ray Shelf > V-Ray NURBS tessellation
width5%
width35%
||V-Ray Menu|| > V-ray Ray NURBS TesselationTessellation
Image RemovedImage Added
width5%
width50%
||Select NURBS surface|| > Create menu > V-Ray > V-Ray NURBS tessellation
width5%
width5%
width20%
