width62%
The V-Ray Scene node is the result of importing a .vrscene file into your scene from the V-Ray Scene Manager. Its parameters are available in the Attribute Editor after import.
For detailed information on how to export a .vrscene file, see the Exporting and Using V-Ray Scene Files tutorial.
UI Text Box
typetip
V-Ray Object Properties can be assigned to VRayScene nodes to override properties like primary visibility, matte properties and other.
UI Text Box
typetip
A VRayScene object can also be loaded by dragging and dropping a .vrscene vrscene file directly in your viewport.
width5%
width33%
