This page introduces the volumetric and environment effects for V-Ray for Maya.
HideElements
cssselector#tocVertical, #tocHorizontal
width55%
The Volumetric effects in V-Ray simulate fog, atmospheric haze and participating media for a number of image effects. Volumetrics also include Volumetric Grid rendering that works with grid based cache formats to create effects such as dynamic plumes of smoke.
Most of these effects are available in the Hypershade, with the exception of the Volumetric Grid, which is available from the V-Ray Shelf.
UI Expand
titleUI Path: ||Hypershade|| > Create panel > VRay section > Volumetric (for all Volumetrics except the Volumetric Grid)
width10%
width35%
width10%
width35%
||V-Ray Shelf|| > Volumetric Grid
(Volumetric Grid only)
width10%
width5%
width40%
Image courtesy of Leticia Reinaldo Gillett
True Atmospheric Effects
True atmospheric effects are applied throughout the entire scene as viewed from the viewport. While parameters give limited control over the appearance of the effect, atmospheric effects render faster than volumetric effects.
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1100px
Columns1repeat(3, 1fr)
Columns1width1740px
Columnsrepeat(4, 1fr)
Columns2width1290px
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkVRayAerialPerspective
Aerial Perspective
Adds a depth effect by causing distant objects to be less distinct.
Textboxcard
CardPageLinkVRayEnvironmentFog
Environment Fog
A fog effect throughout the scene, with control through maps and distance settings.
Textboxcard
PageToIncludeInstallation
CardPageLinkVRaySimpleFog
Simple Fog
Very simple fog with no maps. Can simulate fog, atmospheric dust and so forth.
Div
alignleft
classdashboard
Textboxcard
CardPageLinkVRayToon
V-Ray Toon
Produces cartoon-like outlines on all objects in the scene.
Volumetric Effects
Volumetric effects use a volume to contain the atmospheric effect. While volumetric effects offer a great deal of control over the placement of the effect, they take longer to render.
Div
alignleft
classdashboard
Textboxcard
CardPageLinkVRayScatterFog
Scatter Fog
Scatters fog within a volume. Creates a volumetric effect that traces scattered light inside a volume.
Textboxcard
CardPageLinkVRaySphereFadeVolume
Sphere Fade Volume
Places the fog effect within a spherical gizmo, with a fade-out at the edges of the gizmo.
Textboxcard
CardPageLinkVRayVolumeGrid
Volumetric Grid
Imports, shades and renders grid-based volumetric simulation data into V-Ray for Maya.
