width62%
To make only certain light object(s) to affect the Environment Fog, navigate to the Outliner and make the selected light(s) a member of the Environment Fog set.
Set the Light Mode to either Override shape lights or Intersect with shape lights.
width5%
width33%
Common
width62%55%
Enabled – Enables or disables the VRayEnvironmentFog.
Color – Defines the color of the fog when it is illuminated by light sources. You can also use a texture map to drive the fog color. For more information, see the Color example below.
Emission – Controls the fog emission (self-illumination). You can use this parameter to substitute the ambient illumination inside the fog, instead of using GI. For more information, see the Emission example below.
Emission Multiplier – Multiplies the Emission parameter.
Phase Function – Controls how the light scatters inside the fog. Default value of 0.0 scatters the light uniformly in all directions. Positive value makes the light coming from a certain light source scatter mostly forward. Negative value results in it scattering backwards. See the Phase Function example below for more information.
Fog Distance – Controls the fog density. Larger values make the fog more transparent, while smaller values make it denser. For more information, see the Fog Distance example below.
Fog Density – A multiplier for the Fog distance parameter. It allows a texture to be used for the density of the fog.
Transparency – Controls the color of the volumetric shadows and the tint for the objects seen through the fog. Brighter colors make the fog more transparent, while darker colors make it more dense at a distance given by the Fog distance parameter. See the Transparency example below and the How to create underwater shots with fog color transparency video for more information.
Fog Height – If the fog is not contained within a volume, it is assumed to start from a certain position along the scene's up-axis and continue downward indefinitely. This parameter determines the starting point along the up-axis. For more information, see the Fog Height example below.
UI Text Box
typetip
When the fog is added to a gizmo, the Height parameter has no effect. When the fog is added to the environment or in a container, then the Height parameter determines the starting point in scene units.
See the How to Set Up section for more details on how to use the fog in a container, or a gizmo, or as an environment effect.
Light Mode – Allows you to specify which lights are considered when rendering the environment fog. It is used when you have certain lights affecting just specific objects in the scene while another group of lights is affecting the environment fog. Note that V-Ray GPU does not support light modes yet.
No lights – The lights in the scene do not affect the environment fog.
Use shape lights(default) – The lights attached to the environment fog set are ignored. Only the lights affecting the shape where the fog resides are used.
Override shape lights – Only the lights affecting the environment fog set are considered.
Intersect with shape lights – Only lights that are affecting both the shape and the environment fog set are considered.
Add to shape lights – Both lights that are affecting the shape and the environment fog set are considered.
For more information, see the Volumetric Caustics example below.
Ior – Index of Refraction for the volume, which describes the way light bends when crossing the material surface. A value of 1.0 means the light does not change direction.
width5%
width33%40%
Image RemovedImage Added
Anchor
color
color
width25%
width50%
Image slider
Panel
borderStylenone
fog color = whitewhite
Panel
borderStylenone
Image Added
fog color = green
Panel
borderStylenone
Image Added
A Gradient Ramp texture with Solid interpolation.
The fog density is mapped with a checker texture.
Panel
borderStylenone
Image Added
A Noise texture with Turbulence type
Move the slider to see the example renders.
width25%
Anchor
phase
phase
Example: Phase Function
This example uses back lighting and the Scatter GI is turned on with 1 bounce.
width25%
width50%
Image slider
Panel
borderStylenone
Image Added
Fog phase function = -0.75
Image Removed
fog color = green
Panel
borderStylenone
Image Added
Fog phase function = 0
Image Removed
Panel
borderStylenone
Image Added
Fog phase function = 0.75
Image Removed
width25%
Anchor
fogDistance
fogDistance
GI (Indirect illumination)
width62%55%
Scatter GI – When enabled, the fog also scatters global illumination. Note that this can be quite slow. In many cases, global illumination within the fog can be substituted with a simple emission term. When this option is enabled, the currently selected global illumination algorithm in the V-Ray settings are used to accelerate GI inside the volume (e.g. the light cache or  or brute-force). For more information, see the Scatter GI and Scatter bounces example and the Importance of GI example below.
Scatter bounces – When Scatter GI is enabled, this controls the number of GI bounces that are calculated inside the fog.
width5%
width33%40%
Anchor
scatterGI
scatterGI
Example: Scatter GI and Scatter bounces
Raymarching
width62%55%
This sampler is used when any of the fog properties (color, density or emission) is mapped with a 3d texture. The sampler steps through the volume, evaluating volumetric textures and lighting, until it leaves the volume (if the fog is contained within a volume), or until the accumulated volume transparency falls below a certain cut-off threshold, or until a specified number of maximum steps is reached.
Step size – Determines the size of one step through the volume. Smaller steps produce more accurate results but are slower to render. In general, dense volumes require smaller step sizes than more transparent volumes. In practice, step sizes that are two to three times smaller than the Fog distance parameter work well. Step size is calculated in scene units.
Max steps – Specifies the maximum number of steps through the volume.
Texture samples – Determines the number of texture samples for each step through the volume. This samples textures more accurately than the volumetric lighting. It is useful in cases where the textures vary much faster than the lighting itself (e.g. for detailed fractal textures). For more information, see the Texture samples with Ray marching example below.
Cut off threshold – Controls when the raymarcher stops traversing the volume. If the accumulated volume transparency falls below this threshold, the volume is considered opaque and tracing is aborted. Higher values make the rendering faster but may introduce artifacts. This parameter is not available when the render engine is set to CUDA.
Deep Output – Toggles writing deep data to the file. Note that enabling this option forces ray marching even for simple volumetrics which can cause slower rendering.
width5%
width33%40%
Example: Step size with ray marching
Fade Out
width62%55%
Fade out mode – Allows you to choose between two different modes of fade out.
Fade out radius – Allows you to set a radius for the fade out of the fog.
Per Object Fade Out Radius – When enabled, the fade out effect is applied to each fog volume independently using the Fog Fade Out Radius Extra V-Ray Attribute.
UI Text Box
typenote
V-Ray GPU does not support these parameters yet.
width5%
width33%40%
Ray Filter
width62%55%
Affect background – Enables or disables the tracing of background rays through the volumetric.
Affect Alpha – Enables or disables the tracing of Alpha rays through the volumetric.
Affect reflection rays – Enables or disables the tracing of reflection rays through the volumetric.
Affect refraction rays – Enables or disables the tracing of refraction rays through the volumetric.
Affect shadow rays – Enables or disables the tracing of shadow rays through the volumetric.
Affect GI rays – Enables or disables the tracing of GI rays through the volumetric.
Affect camera rays – Enables or disables the tracing of Camera rays through the volumetric.
width5%
width33%40%
Fancy Bullets
typecircle
  • When using VRayEnvironmentFog with weak VRayLights, it may be necessary to turn down the Cut-off threshold parameter of the lights. The default value for this parameter works fine for surfaces, but for volumes, where a lot of weak light contributions are added together, it may produce a visible sharp boundary where the light calculations stop.
  • You can use the various procedural textures to modify volume properties.
  • V-Ray does not have separate global illumination maps for volumetric rendering. Instead, all GI engines (the irradiance map, light cache, global/caustics photon maps) have been modified to support volumetric data.
  • V-Ray GPU render does not support Mapping options yet.
  • V-Ray GPU render does not support IOR attribute yet.
  • Anchor
    notes
    notes
    To use a fog container with CUDA, first add the fog as a Volumetric override, then add the shape to the fog set.
  • Probabilistic volumetrics make textured fog shading much faster, but also it can result in noisier renders with low sample counts.
  • There is a slight difference between renders containing textured fog with version 5 and version 6. The discrepancy can be fixed by lowering the Step size parameter.
