width50%
 In this tutorial, you will learn how to create a simple scene with XGen primitives to produce a grassy surface.
UI Text Box
typenote
Before proceeding with this tutorial, it is advisable to read the XGen General page first.
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Free Trial
urlhttps://www.chaos.com/free-trial?utm_campaign=docs-tutorials&utm_medium=website&utm_source=docs.chaos.com
width5%
width45%
Part I: Creating a Grass in a Simple Scene
These steps will guide you through creating a simple grass surface.
width55%
Set Up the Splines
Here we will show you how to instance splines to create grass in your scene.
First create a plane and with XGen, assign a description with splines randomly across the surface.
Note: There is no problem using groomable splines, but we will use normal splines to show you how to control their attributes with expressions/maps procedurally.
width5%
width40%
From the Preview/Output tab, set the Percent attribute to 10 (this will affect only the viewport).
Create a V-Ray Dome Light in the scene and render. Your rendering should look similar to the image below.
Part II: Randomizing Hair Strand Color
There are two parameters that control the color of each strand: root_color and tip_color. If different colors are assigned to both, the color of each hair strand will be interpolated upwards from the root color to the tip color. If only one color is assigned to both, the whole strand will be colored evenly with that color.
width55%
Colorize the Roots
Here are the steps to colorize splines:
Assign a V-Ray Hair Sampler to the Diffuse Color of the material.
Go to the Preview/Output tab of the XGen window and scroll down to the Custom Shader Parameters section. Add root_color as type color as shown.
width5%
width40%
width55%
You should then see your parameter added above the textbox, and now an expression can be assigned to it.
Use this expression for the custom shader parameter:
Code Block
languagephp
[rand(0.3,0.7), rand(0.3,1),rand(0.3,0.7)]
Render the scene.
width5%
width40%
width55%
Colorize the Tips
We can also use the tip_color together with the root_color.
A texture map could be also used, as described on the XGen General page.
Using this setup and an image of painted easter eggs, we get the following render as a result. Notice how the root part of the strands remains green.
width5%
width40%
width55%
If you don't want to be restricted to just two colors along the strand, you can use a ramp texture. This time instead of directly connecting the V-Ray Hair Sampler, assign a ramp texture to the Diffuse color of the material. Connect the distanceAlongStrand of the V-Ray Hair Sampler to the vCoord of the ramp texture. Your shading network should look like this:
width5%
width40%
width55%
Or you can combine both methods. First you paint your root and/or tip color as in earlier steps. But instead of connecting the V-Ray Hair Sampler directly to the material, use a ramp texture with and attach the V-Ray Hair Sampler as a color at the positions you want to sample the textures. Your shading network should look like this:
width5%
width40%
Tessellation Parameters
width55%
V-Ray has options for the tessellation of XGen splines.
Go to the Preview/Output tab, and from the Output Settings choose V-Ray as the the Renderer. Find the V-Ray Settings in the Preview/Output tab.
The Hair Tessellation Mode and the slider below it can be used to tweak the tessellation and thus rendering speed, memory footprint and quality.
width5%
width40%
Limitations and Problems
When working with groomable splines, if a render or a IPR render happens, to continue updating the splines with respect to the groom splines, one has to refresh XGen, groom a bit more and refresh again. Only then will the splines regenerate accordingly to the groom splines (which are only for the viewport).
