This page provides information on the Import V-Ray material from vrscene dialog.
width75%
The V-Ray Material Importer tool is used to import any V-Ray material exported from a .vrscene file into Maya. If importing from a supported vrscene file (one created in Maya), the parameters and settings are still available and adjustable as opposed to using
VRmat Material. Importing vrscene files from other applications may not support all parameters and settings and therefore are brought in as plugin node material versions.
UI Expand
titleUI Path: ||V-Ray menu|| > Tools > Import V-Ray material from file
width30%
||V-Ray Shelf|| > Import V-Ray material from file button
Image Removed
Image Added
width5%
width30%
||Create menu|| > V-Ray > Import V-Ray material from file
Image Modified
width5%
width30%
Image Removed
Image Added
width5%
width20%
Image Added
Interface and Parameters
width62%
File – Shows the filename and path of the vrscene file selected for import.
(Open/Browse window) – Traditional folder icon button used to select the vrscene file to load into the importer window.
Materials – A list of all V-Ray materials found in the loaded vrscene file that can be imported.
Duplicate Materials – Additional copies of selected materials will be imported into the scene if they already exist.
No Duplicate – If a selected material is already present in the scene, an additional copy will not be imported. Only new materials to the scene will be imported with this option.
Select All button – Highlights all materials listed in the Materials section of the importer window.
Import button – Activates the importing process to bring in selected materials.
width5%
width33%
width45%
This example shows how to import a proxy material into Maya using Import from File. The V-Ray material is created in 3ds Max and the scene is exported using the V-Ray Scene Exporter. The scene is then imported into Maya, by using VRay's Import from File Image Removed Image Addedfunction and locating the exported scene. V-Ray imports the material into Maya and it is available for editing.
width5%
width50%
