With the vray objectProperties command you can create, assign or remove object properties from objects. These commands correspond to the Create > V-Ray > Object Properties menu, V-Ray shelf, and V-Ray menu.
Syntax
The vray objectProperties runs without flags. Instead, valid arguments need to be given in strings:
