This page provides information on the V-Ray Light Lister window.
The V-Ray Light Lister window provides an easy way to modify common attributes of all of the lights in the scene.
UI Paths:
section
width10%
width35%
||V-Ray Shelf|| > V-Ray Light Lister
Image Removed
width10%
width30%
V-Ray menu > Light Lister
Image Removed
width20%
UI Text Box
typetip
V-Ray Light Lister window position can be reset from V-Ray menu > Settings > UI > Reset Light Lister Window.
General Light Lister Parameters
width50%
Refresh – Updates the listed lights if lights have been added or removed from the scene.
Isolate – When enabled, isolates a single light for IPR. The isolated light is on in the scene, while all other lights are turned off. See the Example below.
Enable – Enables the light in the scene. See the Example below.
Color – Specifies a color for the light.
Intensity – Specifies the intensity of the light.
Invisible – When enabled, the shape of the light source is invisible in the rendered image.
Shadows – When enabled, the light casts shadows. Disable this option to turn off shadows for the light.
Affect Diffuse – When enabled, the light affects the diffuse properties of the material.
Affect Specular – When enabled, the light affects the specular of the materials.
Affect Reflection – When enabled, the light appears in reflections of the materials.
width5%
width45%
Anchor
example
example
Examples
Isolate option
Enable option
