Floatingpagetoc
This page provides information about the menus of Chaos Vantage.
Chaos Vantage has menus that give you access to a range of functionalities for managing your scene performance and settings.
UI Text Box | ||
You can use the right mouse button click to reset the parameters numeric values to defaults. |
File
Section | |||||||||||||||
direction | horizontal |
title | Rendering |
width | 60% |
Light cache – Enables light cache.
Filter primary rays – Enables filtering for primary rays.
Cell size (world) – Specifies the size of a single voxel, in scene units that is used for the Light cache calculations. Low values will produce more accurate lighting but will impact performance.
Sample limit – Specifies the maximum samples per pixel for refining the image.
Retrace thresh. – Specifies the extent to which GI near corners are retraced instead of being read from the light cache. A value of 0.0 disables retracing.
Misc.
Transparent shadows – Enables materials to cast transparent shadows.
AA filter – Enables the use of Anti-aliasing filter.
Total ray bounces – Specifies a limit for reflection and refraction bounces.
Area lights
Num samples – Specifies the number samples that area lights cast.
Rect. sampling – Specifies the way rectangle lights are sampled.
Area – It is faster for calculations (faster FPS) but clears the image more slowly.
Reprojection – It is slower for calculation (smaller FPS) but clears the image faster. From the very first sample, you can notice that there is far less noise than when using Area.
MIS mode – Selects the Multiple Importance Sampling mode for the lights.
Column | ||
Column | ||
title | Post-Processing |
Thumbnailspagesettings | ||||||||||||||||||
Responsivegridmacro | ||||||||||
Div | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
width | 60% |
Denoising
Spatial filter strength – Specifies the spacial filter strength.
Temporal denoising – Enables denoising of the previous frames. When disabled, the current frame is denoised on its own.
Spacial denoising – Enables spacial denoising.
Spacial iterations – Controls one of the parameters for quality of denoising. Higher values make denoising more stable.
Temporal AA – Applies time based anti-aliasing
H./V. overscan – Scales the image, so that border pixels can be denoised better.
Animated noise pattern – Enables the generation of random numbers (noise) for each frame.
Column | ||
Column | ||
title | Camera |
width | 60% |
Motion blur – Enables motion blur.
Exposure time(s) – Specifies the amount of time the camera shutter is opened in sec. Small values produce less blurring while big values produce more blur.
Collisions
Step height ratio – Adjusts sensitivity when climbing steps or obstacles. Higher values allow stepping on higher surfaces.
Height tolerance – Specifies the height up to which no collision is detected. For example, if you have small rocks or grass below that value, they are ignored and the camera does not bounce up and down.
Gravity – Specifies the acceleration applied on the camera when collision is enabled.
Column | ||
Column | ||
Edit
Column | ||
Undo – Reverses your last action. You can reverse more than one action. (Shortcut: Ctrl+Z ) Redo – Reverses your last Undo. You can reverse more than one action that has been undone. (Shortcut: Ctrl+Shift+Z ) Undo Switch Camera – Reverses your camera transformation. (Shortcut: Alt+Z ) Redo Camera – Reverses your Undo Switch Camera actions. (Shortcut: Alt+Shift+Z ) Preferences – Opens the Preferences window. See the Preferences section below. Render Devices – Opens the Render Devices window. See the Render Devices section below. Mouse and Key Shortcuts – Opens the Shortcuts window. Check the Shortcuts page for additional information. Saves Scene Settings as Default – Saves the current scene settings as default settings for all projects. This will override the defaults.vantage file located in %Appdata%\Chaos Group\Vantage. Reset Default Scene Settings – Resets the scene settings to their default values. This will reset the default.vantage file located in %Appdata%\Chaos Group\Vantage to its default state. |
width | 5% |
Column | ||
title | Files |
width | 60% |
Save camera in Vantage file – Saves the last camera position in viewport in a .vantage file. When disabled, saves the render settings in a .vantage file without saving camera changes.
Opacity (alpha) in quick saved PNG – When enabled, stores the environment in the alpha channel of the quick saved .png file using the Quick save snapshot button().
Load startup scene – Enable to load the test startup scene provided by Chaos.
Pause when app loses focus – Pauses rendering when the app loses focus. This applies to interactive rendering only.
UI Text Box | ||
The Pause when app loses focus option will be ignored when in Live Link session |
Safe GPU allocation – When enabled Chaos Vantage will try not to use more GPU memory than the available physical memory. This prevents crashes and/or reduces system performance. Disabling this may lead to crashes with heavy scenes.
Dropped scenes
Ask – When a .vrscene is dropped into the viewport, Chaos Vantage asks you whether to open, merge or place the scene.
Open – When a .vrscene is dropped into the viewport, Chaos Vantage opens the scene.
Merge – When a .vrscene is dropped into the viewport, Chaos Vantage merges the scene at origin 0,0,0.
Place – When a .vrscene is dropped into the viewport, Chaos Vantage merges the scene at the position of the red arrow indicator aligned to the normal of the surface.
Merge geometry – When a new .vrscene is dragged and dropped into the viewport, the geometries are merged into the scene.
Merge materials – When a new .vrscene is dragged and dropped into the viewport, the materials are merged into the scene.
Merge lights – When a new .vrscene is dragged and dropped into the viewport, the lights are merged into the scene.
Merge cameras – When a new .vrscene is dragged and dropped into the viewport, the cameras are merged into the scene.
width | 5% |
Column | ||
title | Interaction |
width | 60% |
Selection
Outline – Enables outlining of objects in the scene. This means that selected or highlighted objects have a thin line around them with color specified in the Highlight color and Selection color.
Highlight – Enables highlighting of objects in the scene. This means that selected or highlighted objects are filled with a semi-transparent color specified in Highlight color and Selection color .
Highlight shadowing – Enables occlusion of the highlighted/selected objects behind other objects in the scene.
Outline inner contours – Outlines objects when multiple overlapping objects are selected.
Highlight during moves – Enables highlighting of objects during transformations.
Highlight color – Specifies a color for the outline when highlighting an object.
Selection color – Specifies a color for the outline for the selected object.
Color opacity – Controls the opacity of Highlight and Selection colors.
Cam transition time – Specifies the time for transition between saved cameras.
Auto exposure time – Specifies the duration of smooth transition between calculated exposure values.
Mouse sensitivity – A multiplier for the mouse sensitivity when using dolly, orbit and camera zoom.
Auto-trim recorded camera – Removes repeated frames without movement from both ends of the recording.
Navigation
Roll snap – When using the roll hotkey(Ctrl+MMB drag), if the roll angle falls below this value, the camera snaps back to horizontal position/0 degrees roll.
Column | ||
Column | ||
title | Render Defaults |
width | 60% |
Interactive Denoiser
Type - Sets the type of the denoiser that will be used in the viewport.
NVIDIA AI – Uses NVIDIA AI denoiser that provides superior final quality when many render samples are accumulated over time.
Vantage – Uses the native Vantage denoiser that produces sharp initial image, but some artifacts remain even when more render samples are accumulated.
Combined –Uses the Vantage denoiser initially and then after specified samples in the Switch after parameter switches to NVIDIA OptiX denoiser.
Switch after – Specifies the amount of render samples that need to be accumulated before switching to the NVIDIA OptiX denoiser when the denoiser type is set to Combined.
UI Text Box | ||
NVIDIA AI denoiser requires NVIDIA display driver 466.11 and newer. |
UI Text Box | ||
Combined denoiser type uses more memory. |
Column | ||
Column | ||
title | UI |
width | 60% |
Window always on top – When enabled, the app window will be forced to be drawn on top other windows even when it is not in focus.
Show side panels on hover – When enabled, if the side panels are hidden they show up when the mouse is hovered over them. Otherwise, a click is required.
Display controls for all lights – When enabled, each light is listed in the Lights tab individually. When disabled, lights are grouped in the Lights tab and those with identical parameters are instances.
Enlarge font – When enabled, enlarges the UI font for better readability.
Popup dialogs for advanced camera properties – When enabled, the advanced camera properties are displayed in a separate popup window.
Column | ||
Column | ||
title | Feedback Program |
width | 60% |
In the Feedback Program tab the participation for customer feedback settings for Chaos Vantage can be changed.
Column | ||
Column | ||
Column | |||||
Select automatically – Selects the render device(s) based on their compute power automatically. Change device order — Moves the selected device up or down in the list when Select automatically is disabled. The first devices has some additional load than the secondary. List of available devices - Specifies which render device(s) will be used for rendering when Select automatically is disabled.
width | 5% |
Column | ||
Select
View
Tools
title | Still image |
width | 60% |
Render output – Specifies the render output - a still or an animation sequence
Resolution Preset – Sets the render resolution from 4 predefined resolutions:
720p; 1080p; 1440p; 2160p(4K)
Aspect - Sets the aspect of the render resolution.
Width – Sets the width of the rendered snapshot in pixels.
Height – Sets the height of the rendered snapshot in pixels.
Samples – Specifies the samples per pixel for refining the image.
Pixel buffers – The amount of additional memory required for the currently set render resolution.
Auto-exposure – When enabled, exposure will be automatically calculated. Set exposure in camera will be ignored.
Denoiser – When enabled NVIDIA AI denoiser will be applied to the rendered image. Denoiser amount will be 0, when disabled or 100, when enabled.
Denoiser Stats – The amount of additional memory required for the denoiser for the currently set render resolution.
Light Cache – Enables Light Cache when rendering.
Light Cache Stats – The amount of additional memory required for light cache for the currently set render resolution.
Motion Blur – Enables the rendering of motion blur for the rendered image with the settings set in File > Advance Scene Settings > Camera > Exposure time.
Approx. GPU memory needed – Displays an approximation of the needed GPU memory for the currently set render resolution and settings.
Camera enqueue mode – Sets the mode that specifies how cameras are added to the render queue when Add to Queue button is pressed.
One – When Add to Queue button is pressed, only the cameras specified in Camera drop-down will be added to the render queue.
All – When Add to Queue button is pressed, all scene cameras will be added to the render queue.
Camera – Specifies the rendering camera from a list of available scene cameras or <current camera> position.
Camera Type – Specifies the type of the camera to be used when rendering a snapshot.
Perspective – Sets the current scene camera to be used to render the snapshot.
Cube 6x1 – Sets the use of a Box camera with the cube sides arranged in a single row useful in generating cubic VR output.
Stereo Cube 6x1 – Sets the use of a Left/Right stereo Box camera with the cube sides arranged in a single row useful in generating cubic stereo VR output.
Spherical – Sets the use of a spherical camera with independent horizontal (FOV X) and vertical (FOV Y) FOV selection that is useful for generating latlong images for spherical VR use.
Stereo Cube 6x1
Stereo spherical – Sets the use of a spherical Left/Right stereo camera with independent horizontal (FOV X) and vertical (FOV Y) FOV selection and that is useful for generating latlong images for spherical VR use. The stereo strength can be adjusted by modifying the Eye dist parameter.
FOV X – Specifies the horizontal field-of-view angle. Available only when Camera Type is set to Spherical or Stereo spherical.
FOV Y – Specifies the vertical field-of-view angle. Available only when Camera Type is set to Spherical or Stereo spherical.
Eye dist – Specifies the eye distance for which the stereoscopic image is rendered. Available only when Camera Type is set to Stereo Cube 6x1 or Stereo spherical.
Focus rotation – When enabled the left and right views are rotated so that their focus points coincide at the distance specified by the Focus Distance parameter in the Camera tab. When disabled the left and right views directions are parallel.
Top/Bottom – When enabled, the output layout for the views will be Top(for left eye) and Bottom(for right eye). When disabled, the output layout will be Left(for left eye) and Right(for right eye).
Save PNG alpha – When enabled, stores the environment in the alpha channel of the .png file. In the ''Save Image' window a .png file format must be specified.
Output path – Specifies the output file path where the still image is saved.
Add to Queue – Adds currently set camera in Camera option and current to a queue for batch rendering multiple cameras or animation sequence.
Show Queue – Shows the batch rendering queue list of added cameras. See the Render queue section below.Start Queue – Starts batch rendering of the added cameras and/or animation sequences. Button is disabled if there are no cameras in the batch rendering queue.
Delete Queue - Clears the batch rendering queue. Button is disabled if there are no cameras in the batch rendering queue.
Start – Starts rendering of the set Camera and current render settings. Button is disabled if there are cameras in the batch rendering queue.
Cancel – Closes the Render setup dialog.
UI Text Box | ||
In the 'Save Image' window a .png or .exr file type must be added after the specified file name e.g Camera01.png or Camera01.exr |
UI Text Box | ||
Set values and parameters are auto saved and will be used between sessions. |
Column | ||
Column | ||
title | Sequence |
width | 60% |
FPS – Specifies the frames per second for the animation.
First frame – Specifies first frame of the animation sequence.
Last frame – Specifies last frame of the animation sequence.
Auto-exposure – When enabled, exposure will be automatically calculated for each frame. Set exposure in camera will be ignored.
Reduce flickering – Enables temporal rendering of the AI denoiser. Results and details may be blurry when enabled. Disabling it may increase image sharpness.
Stereo Cube 6x1
Output file type – Specifies the file type for the rendered sequence.
Image – Output of the animation will be an imagesequence. In the ''Save Image' window a .png or .exr file format can be specified for the image sequence.Image + MP4 – Output of the animation will be an image sequence and an .mp4 file. In the ''Save Image' window a .png or .exr file format can be specified for the image sequence.
Image + MKV – Output of the animation will be an image sequence and an .mkv file. In the ''Save Image' window a .png or .exr file format can be specified for the image sequence.
MP4 – Output of the animation will be an .mp4 file.
MKV – Output of the animation will be an .mkv file.
UI Text Box | ||
UI Text Box | ||
Column | ||
Column | ||
width | 60% |
When checked, enables the rendering of the camera/animation sequence in the render queue.
Name of render queue item.
Removes the camera/animation sequence from the render queue.
Column | ||
Column | ||
Live Link
Cosmos
