This page provides information on the V-Ray Fresnel Map.
floatingpagetoc
width
50%
VRayFresnel is a simple texture map that blends two colors or maps based on the angle of view and an index of refraction. For example, the user can connect the VRayFresnel texture to the specular color of a normal Maya material in order to create fresnel reflection.
To illustrate the texture's effect, the example on right shows VRayFresnel applied to the diffuse channel of a VrayMtl. The Front Color is set to Black, the Side Color is set to a bright cyan, and the IOR is set to 2.0
