With Chaos Cloud you are able to submit, queue, monitor, and organize your render jobs across projects. To manage render jobs in Chaos Cloud you can use its web-based interface or a command line interface. This page explains how to manage render jobs in the web-based interface of Chaos Cloud.
UI Text Box | ||
Your Credits Balance is now displayed on each Chaos Cloud portal page. It is visible in the top right corner next to the login information. |
Managing Jobs Through the Web Interface of Chaos Cloud
The Projects tab hosts all render jobs submitted to Chaos Cloud. It allows organizing jobs in multiple projects, and it is also where you can download the output of your render, resubmit a render, or delete a render from Chaos Cloud. Every render job needs to be allocated to a project.
Section | |||||||||||||||
Jobs
Section | ||||||||||||||||||||||||||||||
Download Options
Queue
The Queue tab is where all newly submitted, paused, or queued render jobs appear. From here you can monitor, pause, or cancel them. No completed render jobs are listed here - they are all found at their respective project folder, allocated upon submission.
