Clicking on a project shows its contained render items. Here you can monitor, pause, cancel, move, delete, or download a render job.
To pause an ongoing render, go to the Settings button () and select Pause.
To cancel an ongoing render altogether, go to the Settings button () and select Stop.
To delete a completed render, press the Delete option.
You can also delete a group of renders. To do so, select the jobs by clicking on them, and then press Delete. Another way is to select the first and last render job while holding Shift.
To move a job to another project, go to the Settings button () and select Move. Then, you can either search for a destination project (by entering the project title or browsing in the project list in a modal window), or you can create a new project and select it from the modal window.
UI Text Box
type
tip
The project list in the modal window can be sorted by name.
To download a completed render job, press the Download.
width
5%
width
40%
Image Modified
Jobs
width
55%
Clicking on a render job within a project opens the Job Details page. The page displays the finished render if it's finished, information about it, as well as additional controls for downloading, resubmitting, or reporting a job.
To download the render job, press the Download button.
To delete the render job, press the Settings button () and select Delete.
To clone the render job, press the Clone button. For more information, see the Clone Option page.
To report the render job, if something went wrong, press the Settings button () and select Report.
To view the render log, press the Settings button ( ) and select View log details.
To rename the render job, press the Settings button ( ) and select Rename.
To move a job to another project, press the Settings button ( ) and select Move. Then, you can either search for a destination project (by entering the project title or browsing in the project list in a modal window), or you can create a new project and select it from the modal window.
UI Text Box
type
tip
UI Text Box
type
tip
The progress of ongoing render jobs can be observed in real-time from the Job Details page.
UI Text Box
type
info
Cloning a render job using the Clone button allows you to set new final render settings.
