width60%
V-Ray Lens Effects simulates real-world camera lens effects such as bloom and glare. The plug-in uses a fast multi-threaded technique to compute the result and provide immediate update in the V-Ray VFB. V-Ray Lens Effects are applied in the effectsResult channel together with other post effects executed over the RGB rendered image.
The Lens Effects layer V-Ray Lens Effects can also be refined via V-Ray masks. Learn more on the Masks page.
The Lens Effects layer is accessible from the Layers panel in the VFB and can be activated becomes active when the lens effects are enabled. It can be blended with the rest of the layers in the VFB.
UI Text Box
typetip
Lens Effects layer can be disabled from the visibility icon (). Disabled layers are indicated by the icon.
UI Expand
expandedtrue
titleUI Path: ||V-Ray Frame Buffer|| > Layers
width5%
width35%
