Section | |||||||||||||||
UI Paths
UI Expand | ||||||||||||||||||||||||||
Menu Options
Since there are multiple options available from the V-Ray Displacement menu, here is a simple breakdown of what they do. Note that objects can only be associated to one displacement set at a time.
Force create VRayDisplacement node – Creates an empty displacement node if no objects are selected. Useful for manually adding objects to the Set from the Outliner.Note:
UI Text Box | ||
A single mouse click on the VRayDisplacement icon in the V-Ray Shelf automatically creates a single set that includes the active selection, or an empty set if no objects are selected. |
Workflow
Section | |||||
32-bit Displacement Maps
Section | |||||
Fancy Bullets | ||
