Anchor | ||||
Context Menu
Render Elements Manager
How to manage Render Elements
Categories
Presets Options
Supported Supported Render Elements
V-Ray supports the following render elements. All render elements support native V-Ray materials.
Render element | Color Depth of EXR floating-point channels | Description |
16bit/32bit | Raw diffuse direct illumination before it's multiplied by the diffuse surface color. | |
Raw GI | 16bit/32bit | Raw diffuse global illumination (not multiplied by the diffuse surface color). Only present if Global illumination is enabled. |
Raw Total Light | 16bit/32bit | The sum of all raw lighting, both direct and indirect. |
Raw Reflection | 16bit/32bit | Pure surface indirect reflection before it is multiplied by the reflection filter color. |
16bit/32bit | Pure surface refraction before it is multiplied by the refraction filter color. | |
Raw Coat Filter | 16bit/32bit | Creates a solid mask showing the areas of reflection in the Coat layer without being affected by Fresnel. |
Raw Coat Reflection | 16bit/32bit | Pure surface indirect reflection from a V-Ray Material Coat layer before it is multiplied by the reflection filter color. |
Raw Sheen Filter | 16bit/32bit | Holds information similar to Sheen Filter RE, but without being affected by Fresnel. |
Raw Shadow | 16bit/32bit | Raw light that is blocked by other objects. |
16bit/32bit | Pure surface indirect reflection from a V-Ray Material Sheen layer before it is multiplied by the reflection filter color. |
