HideElements
cssselector#tocHorizontal, #tocVertical
This page offers information about the V-Ray Background Render Element in Cinema 4D.
width62%
The Background Render Element stores an image of the texture used in the background behind geometry in a scene, as seen from the camera. Geometry that blocks the background image renders as black.
This render element interprets only a background texture, set as Env. Matte Texture (Render Settings > V-Ray > Overrides > Environment).
Other types of manually created backgrounds, such as a plane mapped with a texture set outside a window, are not interpreted as a "background" for the purposes of this render element.
This render element can be used to enhance or edit only the background of a scene after it has been rendered. See the example.
UI Path: ||V-Ray|| > Render Elements > Background
How to add a render element to a scene
Multiexcerpt include
MultiExcerptNameAddBackground
PageWithExcerptAtmospheric Effects RE
width5%
width33%
Image_comparison_slider
LabelBeforebeauty render
LabelAfterbackground channel
Properties
width62%
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color MappingApplies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Filtering –  Applies an image filter to this channel.Derive Raw Channels – Generates data in the raw channels by combining the respective color and the filter color channels.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
width5%
Image Removed
width33%
Image Added
Anchor
example
example
Example: Enhancing the Background
In this example, the background is brightened using the Background Render Element.
Align
aligncenter
LabelBeforebefore
width60%
LabelAfterafter
height60%
