Beta release
Date - 28 May, 2020
Release Notes: V-Ray 5, Beta 2
UI ButtoncolorbluenewWindowtrueicondownloadtitleSign up for Downloadurlhttps://www.chaosgroup.com/beta/vray-3ds-max
width4%
width30%
Light Path Expressions
Output any lighting information into its own render element
width1%
width30%
New VRaySky model
New Sun & Sky dramatically improves lighting before sunrise and after sunset
width1%
width30%
Blue Noise Sampling
Better looking sampling with fewer samples
width4%
width4%
width30%
Selective export to vrscene
Easy way of exporting only parts of the scene
width1%
width30%
Filmic Tone Mapping layer in VFB2
Simulate film response to light
width1%
width30%
VRayProxy as particle source for VRayInstancer
Use particles generated in other DCCs for your instancing in V-Ray for 3ds Max
width4%
